Inventor Forum
modify an stl file with invetor
8 REPLIES 8
Message 1 of 9
giulio.tamagnini
11282 Views, 8 Replies
good evening to all
for a study that I have to do, I did run a company specialized a 3D scan of some engine parts. Files that have given me are .stl that I can not modify or edit with invetor ...so my question is: how can I make these stl files like editable solids??is it possible convert stl to ipt??
thanks
8 REPLIES 8
Message 2 of 9
Message 3 of 9
Thank you for your quick reply,
Yes, I've tried following that guide, but at the end of the conversion I get a report of the proceeding but of the converted file there is no trace. I also tried to use Autocad 3ds Max, but the file that i get is an assembly file and not an .ipt
Message 4 of 9
Hi giulio.tamagnini,
Have you contacted the creator of the addin about this?
If you look at the link you'll see a Cust. Support email address.
I hope this helps.
Curtis
Message 5 of 9
STL format is the mesh data which can only view but not edit. Please try to download the Mesh Enabler tool from Autodesk Lab: http://labs.autodesk.com/utilities/inventor_mesh to convert the mesh features to Inventor Base features. The resulting Base features can then be used for further operations including drawings and measurements. This tool is free.
Kevin-Hongyuan Li
Quality Assurance Team
Autodesk, Inc.
Kevin-Hongyuan Li
Software Quality Assurance Engineer
Design, Lifecycle and Simulation Product Group
Direct: +86 21 2039 6025
Email: Hongyuan.Li@autodesk.com
Autodesk, Inc.
NO. 130, Lane 91, E Shan Rd
Building 12, Floor 6,
Shanghai 200127, PRC
www.autodesk.com
Message 6 of 9
grim2020
in reply to: KevinLi-Autodesk
The labs link is no longer available and the exchange app is subscription only.  I am having the same problem but being an educational institution we do not have a subscription so I guess I'm dead in the water.
Message 7 of 9
mcgyvr
in reply to: grim2020
You can email Scott Shepard.. He should be able to get you a copy.
http://forums.autodesk.com/t5/Inventor-General/STL-to-Inventor-format-Mesh-Enabler-for-Students/td-p...
Message 8 of 9
jfelker81
here ya go, try this
Message 9 of 9
jfelker81
in reply to: jfelker81
nevermind it wont let me attach it, if you need the .msi intaller for the mesh tool just send me a message
