Inventor General Discussion
Active Member
AdskInv
Message 1 of 6 (1,024 Views)
Modelling bicycle gears
1024 Views, 5 Replies
11-05-2012 07:18 AM
My question:
How can I create bicycle gears that have different numbers of teeth but all have an intertooth distance (distance between the teeth centres) of 12.7mm?
My attempt at a solution and problems encountered:
I made a bicycle gear by patterning a small circle around a large circle then trimming lines (see attached sketch), but this method requires me to estimate the diameter of the large circle before patterning and then keep modifying this slightly until I get an intertooth distance as close as possible to 12.7mm. So I can't get exactly 12.7mm. In my sketch I have labelled this intertooth distance I refer to by construction lines.
Thanks in advance.
AdskInv wrote:
 I also need to model a specific chain type. .
What is the chain type?
You could examine the attached file and alter it (or start from scratch) using the basic technique.
JDMather
Message 2 of 6 (1,019 Views)
Re: Modelling bicycle gears
11-05-2012 07:25 AM in reply to: AdskInv
Why not use the Roller Chain Spocket Design Accelerator?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
JDMather
Message 3 of 6 (1,013 Views)
11-05-2012 07:34 AM in reply to: JDMather
In any case, I would not create a complex sketch like that.
It is better to pattern features than to pattern sketch.
If you Right Mouse Button - Show All Constraints - you will see that there are too many constraints that would have to be solved.
Active Member
AdskInv
Message 4 of 6 (1,004 Views)
11-05-2012 07:57 AM in reply to: JDMather
The shape of the teeth is not the shape I want to use. I also need to model a specific chain type. Though I could try and edit them to suit my needs.
JDMather
Message 5 of 6 (987 Views)
11-05-2012 08:17 AM in reply to: AdskInv
Active Member
AdskInv
Message 6 of 6 (976 Views)
11-05-2012 08:46 AM in reply to: JDMather
A Shimano CN HG94 chain. It's a very narrow chain and is also not symetrical. I might just pick the narrowest chain with 12.7mm pitch that the design accelerator offers.
Thanks.
