Inventor General Discussion
Distinguished Contributor
Anthony
Message 1 of 5 (430 Views)
Modelling a cable
430 Views, 4 Replies
01-04-2013 02:36 AM
I was wondering the best way to model a steel tensioner cable in Inventor. The assembly I have designed is of a cable fixed between two brackets which are fastened on two structural beams. I am looking accurately model the cable attachment on the brackets. My inital thought would be to extrude the length of cable through a pre-defined path between the bracket fixing holes however this would not represent a 'true life scenario'. Any suggestions would be appreciated.
Product Design Suite Ultimate 2013
64-bit HP Z400, Intel Xeon W3550 3.07GHz
12.0GB RAM, ATI FirePro V4800 (FireGL)
Anthony Goodwin ~ Cad Manager/Senior Designer
Autodesk Inventor Professional 2013 SP2 64-Bit Edition
Windows 7 HP Z400, Intel Xeon W3550 3.07GHz
*Pro
sbixler
Message 2 of 5 (423 Views)
Re: Modelling a cable
01-04-2013 03:42 AM in reply to: Anthony
Post a picture of what you're trying to accomplish.  You call it a tensioner cable, which leads me to think that it will mostly be straight (i.e. under tension), so I'm not understanding the "true life scenario".
JDMather
Message 3 of 5 (413 Views)
01-04-2013 04:21 AM in reply to: Anthony
Anthony wrote:
...extrude the length of cable through a pre-defined path
That describes Sweep, not Extrude.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Anthony
Message 4 of 5 (396 Views)
Re: Modeling a cable
01-04-2013 05:36 AM in reply to: sbixler
Hi, thank you for your reply. Please see attached screenshot of the intended result. The cables will be under tension as you have stated and will therefore will be represented straight, I may be asked to produce flexible cable as well for further design development which is why I asked the original question. Thank you.
Valued Mentor
rhasell
Message 5 of 5 (311 Views)
01-06-2013 09:59 PM in reply to: Anthony
Hi
The Cable is not the problem here, simple extrude/sweep, the issue is the attachments.
You will need to model up the fittings and tensioner (Shackles, rigging screws, Swage ends, etc) Have a look at "VanBeest" there are a lot of fixings there (All green pin lifting equipment), the rest you will have to look at grabcad, and do your own modeling.
This will give you a better representation of the cable.
Reg
Autodesk PDS Ultimate 2015 Update 1 Build 159
Intel Core i7 (950@3.07GHz)/Win7x64 (Home) - 12GB Ram
Nvidia GeForce GTX 560 Ti
Please Give Kudo's / accept as a solution if it fixes your problem.
