I used a similar (if not identical method) and manage to get a simple
profile to sweep.
If you make it an assymetrical profile, you'll see it twists in a wierd
fashion. Perhaps you can use a set of spirals as rails for a loft?
I'm a bit tied up, but when I can, I'll try it.
See iCF for the file.
Rui
ruivaz@cadmais.pt
www.cadmais.pt
"Tracy Yoho" wrote in message
news:401e7910_1@newsprd01...
> Great job. Thanks for the leg up.
> Tracy
> "mpower" wrote in message
> news:401e508c_2@newsprd01...
> > I played with this some, but I only got as far as creating a helix ring
> > path. I can't get any profile to follow it for some reason. So far,
the
> > only success I've had with it is to sweep a very short line along the
path
> > to create a twisted surface, and that doesn't even follow the path as I
> > expected, but it's a start.
> > -Mike
> > news:401e4d01_2@newsprd01...
> > > Here are a couple more pictures. I don't know how to describe the ends
> > > either but I would be happy with the helix hoop as a start.
> > > "JDMATHER" wrote in message
> > > news:11777402.1075496359675.JavaMail.jive@jiveforum2...
> > > > Got any more views? Trying to figure what is going on at the ends.
