Inventor General Discussion
Member
hydro dan
Message 1 of 5 (102 Views)
Modeling failure in ASM
102 Views, 4 Replies
11-09-2006 05:38 AM
I want to know why I get a "Modeling failure in ASM. Redefine inputs" message when I tried to edit or do a feature, as simple to enter in a sketch, do anything and update. Software is Inventor 11 SP2
JDMather
Message 2 of 5 (102 Views)
Re: Modeling failure in ASM
11-09-2006 06:04 AM in reply to: hydro dan
Can you zip and post an example file exhibiting this behavior.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Distinguished Contributor
shekarsub[Autodesk]
Message 3 of 5 (102 Views)
11-11-2006 08:26 AM in reply to: hydro dan
If you want to send it to us. shekar.subATautodesk.com. Thanks.
shekar
Member
matteo.pallaroni
Message 4 of 5 (102 Views)
11-13-2006 01:05 AM in reply to: hydro dan
Just replace your template, maybe corrupted.
Member
hydro dan
Message 5 of 5 (102 Views)
11-13-2006 06:19 AM in reply to: hydro dan
Thanks to be interested in my case. Sorry I can't send you an example. It seem to does only after a certain time of "operation". If I close my Inventor and re-open the same drawing, the problem does'nt appear. There is 3 other draftman not having this problem and they use same software (V11 SP2) and we share same templates on a network. I had the same error when trying to save copy as .SAT.
Sincerly
