Hey guys and gals,
I am trying to model a coiled ring. Attached is a picture, but the basics are that it needs to be a coiled ring with the coils angled forward about 35 degrees. (The picture should help show you what I am talking about.)
-Thanks
Manny
AIMES Connection Technologies
We AIM to be your CONNECTOR source!
It seems that the best way to do this would be to sweep a circle along a desired path. Anyone have any idea how write the parametric equations for this shape in the picture?
https://www.youtube.com/watch?v=7yw-tQy9VKA
use coil and bend part commands..
AIMESUS,
In addition to the previous replies you can find an example model that might be useful at this link:
http://forums.autodesk.com/t5/Inventor-General/draw-a-SPRING-around-a-circle/m-p/3566844#M443872
You can change the parameters as needed, or just use this model as a guide to create your own.
I hope this helps.
Curtis
