Inventor Forum
model property (AREA) in user parameter
5 REPLIES 5
Jacques.Grobler
1132 Views, 5 Replies
Hi all
Is it possible to have the model AREA (from iProperties) show under the user parameters?
I need it for a calculation that drive other parameters
5 REPLIES 5
wimann
in reply to: Jacques.Grobler
Sure thing. In the ribbon, go to Manage>iLogic>Add Rule. Name the rule as you desire.
In the dialog box type:
<yourparamname> = iProperties.Area
iLogcVb.UpdateWhenDone = True
You may have to run the rule manually or you can set an Event Trigger to run the rule under certain circumstances.
Hope this helps.
-Will Mann
Inventor Professional 2020
Vault Professional 2020
AutoCAD Mechanical 2020
Jacques.Grobler
in reply to: wimann
Hi Wimann
It is easy to do it with iLogic, I am however struggling to get the value as a user parameter:
Manage > Parameters > User Parameters
wimann
I would think that the snippet I provided would do just that. If your parameter was say... "PartArea" then in iLogic:
PartArea = iProperties.Area
I'm fairly certain that will push the area into a user param. However I'm not as sure about the units. Inventor has a unti for area (circular_mil) but I'm not sure how you could incorporate that into your equations.
-Will Mann
admaiora
in reply to: wimann
I suppose that i can get improved..but, alway with iLogic, if there is not it create and push the parameter "AREA" and it update it whenever geometry change.
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Jacques.Grobler
in reply to: wimann
Hi Wimann
Sorry, yes it does work, I tried it yesterday and for some reason I did not get the result I was hoping for, but thank you
@ Admaiora
Neat little trick, I'll store this in my box of tricks for future use
