Inventor Forum
Model curved panel to show flat in drawing
8 REPLIES 8
Message 1 of 9
281 Views, 8 Replies
I need to model a curved panel (.125 sheet
plastic), but I need to show it flat in the drawing.  How could I go about
doing this in Inventor?
FYI... In MDT, I knew of no easy way to do this...
I modeled the part curved (as it will be in the assembly) and drew it in 2D
(flat) on the drawing.  So, if I updated the model, I had to remember to
manually update the drawing.
I hope there's a better way in Inventor.
We have to do this quite often. Thanks...
Brian
8 REPLIES 8
Message 2 of 9
Brian
Is it curved in more than one direction? If not just use the SM tools.... but I am
guessing it is?
Kent
Member of the Autodesk Discussion Forum Moderator Program
"Brian Mears" wrote in message
news:9745A70244A98CE40CDDCCDAC089A5DC@in.WebX.maYIadrTaRb...
> I need to model a curved panel (.125 sheet plastic), but I need to show it flat in the
drawing. How could I go about doing this in Inventor?
> FYI... In MDT, I knew of no easy way to do this... I modeled the part curved (as it will
be in the assembly) and drew it in 2D (flat) on the drawing. So, if I updated the model,
I had to remember to manually update the drawing.
> I hope there's a better way in Inventor. We have to do this quite often. Thanks...
> Brian
Message 3 of 9
It will fold a curve in two directions as well.
~Larry
"Kent Keller" wrote in message
news:4584393921D88015E64FFA5E132B7F9D@in.WebX.maYIadrTaRb...
> Brian
but I am
> guessing it is?
> Kent
it flat in the
curved (as it will
updated the model,
often. Thanks...
> > Brian
Message 4 of 9
Larry
Are you saying it can fold and flatten something that stretches in more than one
direction? If so ...how? I am hoping you haven't shown me this recently and my steel
trap of a mind let it slip through
Kent
"Larry Caldwell" wrote in message
news:55FE33C9B7F6693FFF8E34DB1C780B48@in.WebX.maYIadrTaRb...
> ~Larry
Message 5 of 9
Laurence,
> ~Larry
> > Brian
tools....
> but I am
> > guessing it is?
> > Kent
show
> it flat in the
> curved (as it will
> updated the model,
> often. Thanks...
> > > Brian
Message 6 of 9
I put an example in CF ... but I'm sure you already know about it.
~Larry
news:E136006DF132F8DACA2244ACC5A09B0E@in.WebX.maYIadrTaRb...
> Larry
than one
and my steel
> Kent
> > ~Larry
Message 7 of 9
I put it under subject Fold ... I added one folded the other way too.
~Larry
> Larry
than one
and my steel
> Kent
> > ~Larry
Message 8 of 9
I think Kent was referring to a compound curvature (which IV won't do)?
Message 9 of 9
Thanks Jeff Man I love getting old.... couldn't come up with compound
curvature.
Kent Keller
http://www.MyMcad.com/KWiK/Mcad.htm
"Jeff Howard" wrote in message
news:7D7C428C61CAF842B2628E1D3F3DDD69@in.WebX.maYIadrTaRb...
