Inventor General Discussion
Distinguished Contributor
30 Kudos
Post 1 of 6
Mitering tube
282 Views, 5 Replies
01-04-2013 06:39 AM
I am needing to create some new parts with miters that will reflect how they will be cut on our tube laser.
I have attached a part sample that someone else has created. I have no idea how to change this into a part that will work for me, so I'm wanting to start brand new.
I am needing the surface of the miter to be perpendicular to the material all through the miter.
How would I accomplish this?
I appreciate your help with this.
Lenovo Think Pad
Windows 7 SP 1
64 Bit.
Inventor 2013
ACAD Mechanical 2013
Here's my attempt.  JD, yours still needs some trimming if it is to be used for a real miter, since there's a chunk protruding into the 45° face:
2,132 Kudos
Post 2 of 6
Re: Mitering tube
01-04-2013 09:58 AM in reply to: sps_cad_guy
The part you posted has two different types of miters.
For the straight through cut type use Split with an angled sketch line (or a workplane) to cut the part.
For the perpendicular to material face (I assume you will be creating from flat and then folding up) Extrude the profile as a surface body rather than solid body, then Split or Trim the surface as above and then Thicken.
Attach your attempts at these two techniques if you can't figure it out.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
*Pro
285 Kudos
Post 3 of 6
Re: Mitering tube
01-04-2013 10:42 AM in reply to: sps_cad_guy
30 Kudos
Post 4 of 6
Re: Mitering tube
01-04-2013 11:59 AM in reply to: sbixler
I have never worked with solid bodies or surface bodies, so I went with sbixlers part.
I think I have it close, but when I mirror the second half, a couple of the cuts don't
mirror over.
What am I doing wrong?
Thanks again for the help.
Lenovo Think Pad
Windows 7 SP 1
64 Bit.
Inventor 2013
*Pro
285 Kudos
Post 5 of 6
Re: Mitering tube
01-04-2013 12:08 PM in reply to: sps_cad_guy
In the Mirror feature, choose "Mirror a solid" instead of "Mirror individual features".
30 Kudos
Post 6 of 6
Re: Mitering tube
01-04-2013 12:11 PM in reply to: sbixler
Worked perfectly! Thank you so very much.
Lenovo Think Pad
Windows 7 SP 1
64 Bit.
Inventor 2013
