Inventor Forum
Mitering tube
5 REPLIES 5
sps_cad_guy
444 Views, 5 Replies
Mitering tube
I am needing to create some new parts with miters that will reflect how they will be cut on our tube laser.
I have attached a part sample that someone else has created. I have no idea how to change this into a part that will work for me, so I'm wanting to start brand new.
I am needing the surface of the miter to be perpendicular to the material all through the miter.
How would I accomplish this?
I appreciate your help with this.
Lenovo Think Pad
Windows 7 SP 1
64 Bit.
Inventor 2014 SP2
ACAD Mechanical 2014
5 REPLIES 5
JDMather
in reply to: sps_cad_guy
The part you posted has two different types of miters.
For the straight through cut type use Split with an angled sketch line (or a workplane) to cut the part.
For the perpendicular to material face (I assume you will be creating from flat and then folding up) Extrude the profile as a surface body rather than solid body, then Split or Trim the surface as above and then Thicken.
Attach your attempts at these two techniques if you can't figure it out.
SBix26
Here's my attempt.  JD, yours still needs some trimming if it is to be used for a real miter, since there's a chunk protruding into the 45° face:
sps_cad_guy
in reply to: SBix26
I have never worked with solid bodies or surface bodies, so I went with sbixlers part.
I think I have it close, but when I mirror the second half, a couple of the cuts don't
mirror over.
What am I doing wrong?
Thanks again for the help.
Lenovo Think Pad
Windows 7 SP 1
64 Bit.
Inventor 2014 SP2
SBix26
In the Mirror feature, choose "Mirror a solid" instead of "Mirror individual features".
sps_cad_guy
in reply to: SBix26
Worked perfectly! Thank you so very much.
Lenovo Think Pad
Windows 7 SP 1
64 Bit.
Inventor 2014 SP2
