Hi everyone,
I've created this minimalistic airship shape and would like Inventor to calculate its volume, but it won't show and the update button is greyed out.What might be the issue here? Thanks.
Solved by johnsonshiue. Go to Solution.
Hi! The part contains only a surface body. Physical properties apply only to solid, not surface. You can simply use Stitch command to turn it into a solid. Then you can check the physical properties.
The body from end to end measures 300000mm, which way exceeds Inventor's valid mode range (a cube of 100000mmx100000mmx100000mm centered at origin). You could run into modeling issues with a solid exceeding the range.
Thanks!
