Inventor Forum
Missing surface in solid
2 REPLIES 2
crash_dummy
416 Views, 2 Replies
I have a scanned model of a casting.  It was necessary to delete surfaces to remove the casting flash from the model.
I have lofted/patched/stitched the missing surfaces to close the solid.  Apparently there is a gap somewhere because the model remains as a surface instead of returning to a solid.
HOW CAN MISSING SURFACES BE FOUND IN THE MODEL?
WHAT ELSE CAN PREVENT THE MODEL FROM RETURNING TO A SOLID?
When stitching, the gap tolerance was set to .002".  The model will "rebuild" without any error messages.
2 REPLIES 2
JDMather
in reply to: crash_dummy
Can you zip and attach the file here?
If you go to the Construction Environment (or I assume the Repair Environment) Inventor can show you where the gaps are.
The CADWhisperer YouTube Channel
crash_dummy
Thanks for the information.  A quick review indicates this will do what I need.  I will try it out.
Thanks again.
