G'day all,
I've just installed 2012 and I seem to have a problem with constraints.
The basic problem is that the SHOW CONSTRAINTS command doesn't show the constraints for geometry that clearly has them. For example, if you delete a horizontal constraint from a line and then add a horizontal constraint to the same line, the line will be constrained but the constraint will not show up.
Solved by cwhetten. Go to Solution.
When you click Show Constraints (or press F8), it only shows the ones that are currently applied and it doesn't automatically refresh when you apply new constraints. To see any new ones, you have to hide the constraints (by pressing F9) and then show them again (by pressing F8).
