I have downloaded the entire tutorial file from the website and installed as instructed. Most tutorials seem to be present but there is one that I am missing. I am missing Sheet Metal Parts tutorial however I do have Sheet Metal Parts 2. I have downloaded the file three times and every time it is missing. Any help would be greatly appreciated.
Thank you in advance.
Solved by JDMather. Go to Solution.
Solved by MariaManuela. Go to Solution.
What file is missing - be specific.
What is the url page of the Tutorial where it is asking for this file?
I am downloading to see if I also have this problem.
Is almost done.
Tell you something
Link is http://www.autodesk.com/inventor-tutorial-data-sets.
For the first tutorial [Sheet Metal Parts] has no dedicated folder because it uses Cylinder Clamp files.
The same to the third tutorial [Sheet Metal Styles] because it uses the Electrical Box folder files
If you read the first topic of each tutorial you get information about this.
Hope help
When I follow the instructions here -
to open the assembly
this is what I get. The instructions then proceed to create the sheet metal cover for the assembly.
