Inventor General Discussion
Valued Contributor
39 Kudos
Post 1 of 12
Missing Pattern Dialogue In Mould Design
378 Views, 11 Replies
11-04-2012 01:34 PM
Inventor Pro 2013 SP 1.1
Hi, I’m suing the Mould Design feature of Inventor Professional and need to have four cavities for this mould. When I try to use the pattern function nothing happens. I look at the Wiki help and it says that I have to enter values for X direction X distance etc, but this dialogue box does not appear.
How can I get the box to appear?
Thanks in Advance.
w7u-64sp1,iv14,intel.xeon.e5-2620 0 @2.00 2.00-32gb,gtx560-4gb
Hi cmharb,
How to get a missing dialog box back:
  • start the tool that exhibits the problem
  • press ALT + Space-bar on the keyboard
  • then press the M key (M for move)
This is what happens off screen
  • then Immediately press any of the arrow keys on the keyboard
  • finally, move your mouse around and the dialog box will now be attached to your cursor allowing you to drag it back on screen, just click to drop it in place.
http://inventortrenches.blogspot.com/2011/01/missing-dialog-box.html
I hope this helps.
Curtis
2,122 Kudos
Post 2 of 12
Re: Missing Pattern Dialogue In Mould Design
11-04-2012 05:54 PM in reply to: cmharb
Does it work when you do the Tutorial?
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Employee
19 Kudos
Post 3 of 12
11-04-2012 06:22 PM in reply to: cmharb
Can you see Pattern command from the attached picture?  I also installed 2013 SP1.1 and have this command.
Mingwei Gao
Software QA Engineer
Inventor Quality Assurance Team
Valued Contributor
39 Kudos
Post 4 of 12
11-06-2012 12:57 PM in reply to: MingweiGao
i do not see the Pattern box like that.
Valued Contributor
39 Kudos
Post 5 of 12
11-06-2012 12:59 PM in reply to: JDMather
no have not done the Tutorial , I'Il do them now and see if it makes a differnace.
Valued Contributor
39 Kudos
Post 6 of 12
11-06-2012 01:42 PM in reply to: JDMather
no,  i get to
http://wikihelp.autodesk.com/Inventor/enu/2013/Help/0126-Tutorial126/0807-Tooling_807/0826-Family_M8...
in the tutorial and there is not Pattern box, it might be off the screen.
Anyone know how to get it back?
2,122 Kudos
Post 7 of 12
11-06-2012 01:50 PM in reply to: cmharb
cmharb wrote:
... there is not Pattern box, it might be off the screen.
You don't see the dialog box... ... but do you see the tool on your screen?
Valued Contributor
39 Kudos
Post 8 of 12
11-06-2012 02:02 PM in reply to: JDMather
yes the mouse is a selector and i can sellect a plastic part. But the box for editing the pattern details is missing.
1,702 Kudos
Post 9 of 12
11-06-2012 02:37 PM in reply to: cmharb
Hi cmharb,
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Valued Contributor
39 Kudos
Post 10 of 12
11-06-2012 03:02 PM in reply to: cmharb
