Every time I open a file, ipt, template etc. I am getting an error that I am missing a file called "experiment" in my project file. Is this an Inventor file. how can I get the message to quit appearing, it says that it will slow down the computer if not found.
Solved by mcgyvr. Go to Solution.
Can you post a screenshot of the exact error...
maybe
edit your project file and remove the issue..
or it could be an embedded link in the templates. (open template.. go to links button and delete link)
so yeah.. edit your project file and remove those paths..
@Anonymous wrote:
Inventor will not let me edit the file, it is greyed out
You must close all open files to edit a project file.
