Inventor Forum
Missing Dimensions??
6 REPLIES 6
KENNA1
451 Views, 6 Replies
Another newby here. I think this software is amazing, and I'm having a good time learning all it can do.
I'm practising on parts from the desk of Curtis Waguespack, Sheet 8 of 25, File name: Alignment Bracket.ipt
Description: Hardware, Bracket, R10.
Are there missing dimensions on the front view, or am I just not this good yet?
Thanks for your time.
6 REPLIES 6
johnsonshiue
in reply to: KENNA1
Hi! Not everybody on the forum has the access to the material you mentioned at all time. Could you please upload an image or the drawing you are talking about?
Thanks!
Software Test Engineer
JDMather
in reply to: KENNA1
....or the url.
Is this the reference
http://dl.dropboxusercontent.com/u/53790195/Inventor%20Trenches/Autodesk%20Inventor%20Practice%20Par...
Knowing Curtis, I doubt there are any missing dimensions.
It is more likely that there are implied tangents, symmetry, equal or horizontal or vertical constraints that you are  missing.
Attach your *.ipt attempt here.
JDMather
in reply to: JDMather
If that is the correct reference - I verified that there are no missing dimensions.
KENNA1
in reply to: johnsonshiue
I will certainly try. I have no ?mad skills?.
KENNA1
Thank you sir. I will reexamine it with that in mind.
KENNA1
Thank you.
Just as I suspected. Operator inexperience.
I WILL figure it out.
Failure is NOT an option!
