Another newby here. I think this software is amazing, and I'm having a good time learning all it can do.
I'm practising on parts from the desk of Curtis Waguespack, Sheet 8 of 25, File name: Alignment Bracket.ipt
Description: Hardware, Bracket, R10.
Are there missing dimensions on the front view, or am I just not this good yet?
Thanks for your time.
Solved by JDMather. Go to Solution.
Hi! Not everybody on the forum has the access to the material you mentioned at all time. Could you please upload an image or the drawing you are talking about?
Thanks!
....or the url.
Is this the reference
Knowing Curtis, I doubt there are any missing dimensions.
It is more likely that there are implied tangents, symmetry, equal or horizontal or vertical constraints that you are missing.
Attach your *.ipt attempt here.
If that is the correct reference - I verified that there are no missing dimensions.
