I have a drawing with several dimension on a particular view. Wanting to adjust dimensions, but there are no dimenson "anchor points" to grab...
Any suggestions?
TIA
Mike
Hopefully I'm not misunderstanding your problem, but it is possible to click and drag the dimension anchor points to new view geometry. See the video linked below for a demonstration.
https://chronicle.autodesk.com/main/details/9a630ce3-7f72-47b4-ace5-97d96e6bc0af
If I have misunderstood, please post back and I will try to help.
Cameron Whetten
Inventor 2014
Please click "Accept as Solution" if this response answers your question.
Just grab the bottom end of the extension line. The line will readjust to have you hanging on to the anchor point for reattachment. Drag, drop, rinse and repeat.
(see attachment)
Notice the elevation on the right, has the anchor points that you can grab....
The elevation on the left doesn't, they're missing....
Your dimension type appears to be Projected rather than True.
