There's a few threads going on currently where multiple people are suggesting what used to be the common fix where you startup the install process once more and dig down into Tools and Utilities to install the CC libraries.
With 2015, the only option I am seeing is for Remote Content which will not work for Desktop Content, at least I haven't discovered how to do so if it can be done.
What's the secret? How does someone install Desktop Content after Inventor has already been installed with the 2015 version?
It's probably something very easy I've overlooked.
TIA for any assistance.
Solved by DarrenP. Go to Solution.
go under install products>shared components section>Inventor Content Libraries
DarrenP
Tks,
I choose the "Install, Install on this computer" option and after re-entering the serial number and key, within a screen or two is where you can install additional CC Desktop Libraries.
I was under the impression you would find them under the "Install Tools & Utilities" button which is where you find Remote Content Librairies.
Tks again.
