I realize that the missing browser toolbar phenomenon has been asked a few times on this website, but I am having a problem with the answer.
When I log onto my computer and open Inventor Pro (I believe it is the 2009 or 2010 version, but just might be 2011), I can not see the browser bar that is usually on the left hand side of the screen. I make sure that browser bar is checked under "View," and it is checked. What are the registry editing strings that need to be edited in order to get this to work, or is there another way to do this without editing the registry?
Please help me! I tried the following edit but I cannot find "DockingAreas" under RegistryVersion7.0, and all of that is under HKEY LOCAL MACHINE, not CURRENT_USERS...
"Look at
HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion7.0\DockingAreas\BrowserBar
and see if changing the left and top to match mine helps"
Please help quickly! I need the browser to finish a sketch due very soon.
Try this one:
HKEY_USERS\.DEFAULT\Software\Autodesk\Inventor\RegistryVersion15.0\System\Preferences\Browser
There's 'Left Edge Docking', 'Main Window Docking' and 'Visible' Keys in there for you to play with...
Good Luck
I'm not sure to be honest...
Mine are set to:
Left Edge Docking = 0
Main Window Docking = 1
Visible = 1
Personally, I'd first check to see if they're the same as those above, then, assuming they are the same, change them all to 0, then save the registry and re-start inventor, if nothing has changed, close inventor, then change them back, save, and re-try Inventor.
If that doesn't help at all, I'd look at changing your graphics display settings in Windows.. set your screen resolution to minimum, check Inventor, and then set your screen resolution back to normal... Sometimes this causes windows which may be outside the normal viewing area to move inwards... It's not a bullet proof solution... but that's what I would do.
