I am missing all template files. When opening a "new file". I sent a screenshot in the attachments that shows all template files are missing. I went to those files on computer and they are empty. Is there a way to re install these?
That image shows a template path to 2015, not 2014?
In any case,
try clicking on this arrow and selecting desired file type, this should create a file whether Inventor can find your templates or not.
Then File>Save Copy As> Template to the correct template path.
Hi! The screenshot seems to show that Inventor is looking at R2015 template folder. I guess you might have R2015 installed before and you are using a default project pointing to R2015's folder. You can either create a new project and set the template path to R2014 folder or modify the existing template path to R2014 template folder.
Please note that Inventor is not yet capable of opening a newer release file in an older release.
Thanks!
