Is it possible to maintain constraints of the parent parts when mirroring parts in an assembly?
@PACDrafting wrote:This is not possible.
Logically it is not possible anyways.
Some constraints do come across if BOTH references are in the mirrored set. From the help ...
The Mirror command recreates any constraints that have both references in the set of components that you select for mirror or reuse. If the orientation of the new reference is ambiguous, the new constraint is suppressed.
It is logically possible. Solidworks does it great. You can mirror about a global plane and then drag and watch as the mirrored parts dynamicaly follow in all 3 directions. Definatley an ability that Autodesk needs to play catch up on.
@PACDrafting wrote:Yes but are you going to mirror using a global plane on all occasions?
Since I use a common global coordinate system I would say about 99% of the time.
But SWx can be about any plane or face, I just used global as an example. They have a symertry constraint and width constraint, which inventor doesnt, so its capability is probably based on that technology.
Skeletal modeling using derived parts as composites when references are needed. Most parts have their origin at 0,0,0 and they are grounded in their assembly at 0,0,0. Sub assemblies are also grounded at 0,0,0. Very few mates needed and very few associative sketches. The only exception is when I place standard items from my library, but they are also modelled at 0,0,0 with the global orientation in mind to make it faster to mate them.
No matter which plane I use, if grounding isnt suitable then I manually add the constraints, but its frustrating that there is no symetry or width type mates. Makes it hard when needing to drag things around at the concept stage.
Go to 3min 30 on this video so see what I mean http://www.youtube.com/watch?v=a-dnuZLdsz8&feature=related. To be able to drag and maintain symetry is impossible in inventor because we have to enter an offset value which doesnt update live. Notice also how they have a mirror feature which can be edited, we dont have that either.
Lets hope 2013 brings something new in this area.
I am aware of the SWX method, and just wondered if Inventor had indeed caught up.
Yep, let's hope 2013 brings some usable enhancements.
Thanks for your discussion.
