Inventor Forum
Mirroring an assembly part
11 REPLIES 11
Message 1 of 12
ermin
193 Views, 11 Replies
Is there anyway IV6.0 will let you mirror an assembly part?
Erm
11 REPLIES 11
Message 2 of 12
in reply to: ermin
Yes. Use a derived part...
Open a new part, invoke the derived part command, and navigate to the part
you want to mirror. After you select it, check the mirror option in the
dialog box, and select OK. Save the new part, and insert it into the
assembly. It will remain adaptive to the original part, so changes made
there will be reflected in the mirrored part when you update.
Walt
"ermlen" wrote in message
news:f126c0a.-1@WebX.maYIadrTaRb...
> Erm
Message 3 of 12
ermin
in reply to: ermin
It works if it is a part but if I have an assembly that I want to get the mirror part derive part wouldn't give me the option of mirroring the part.
Erm
Message 4 of 12
in reply to: ermin
Derive the derived assembly into a new part and then you'll
have the option of mirroring
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
It
Erm
Message 5 of 12
ermin
in reply to: ermin
Thanks. It worked. Now will IV7 or SP2 have a way to accomplish this task simpler?
Erms
Message 6 of 12
in reply to: ermin
There have been several discussions about
this.  If you mirror the whole assembly at what point do you stop?  Do
you make left hand threads right hand threads?  Is EVERY part mirrored or
just most?  It gets to be a sticky wicket.
You might want to check this out.  I haven't
used it yet however...
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
...sleep is for the
weak..
Thanks.
Erms
Message 7 of 12
in reply to: ermin
Agreed, Sean.  From a programming perspective,
mirroring an assembly is MUCH more difficult than it sounds.  As I'm sure
you're aware, that application from cadstudio doesn't maintain assembly
constraints, and that would be the difficult part.  I thought about writing
an addin to do exactly that a while ago but realized very quickly that
maintaining the assembly constraints would be next to impossible - especially if
the assembly to be mirrored contained subassemblies.
Do you make left hand threads right hand threads?  Is EVERY part mirrored
or just most?  It gets to be a sticky wicket.
Sean Dotson, PE
...sleep is for
the weak..
Thanks.
Erms
Message 8 of 12
in reply to: ermin
what about a VBA routine to shorten the
double-derive method?
K
perspective, mirroring an assembly is MUCH more difficult than it
sounds.  As I'm sure you're aware, that application from cadstudio
doesn't maintain assembly constraints, and that would be the difficult
part.  I thought about writing an addin to do exactly that a while
ago but realized very quickly that maintaining the assembly constraints would
be next to impossible - especially if the assembly to be mirrored contained
subassemblies.
stop?  Do you make left hand threads right hand threads?  Is EVERY
part mirrored or just most?  It gets to be a sticky
wicket.
haven't used it yet however...
Sean Dotson, PE
...sleep is for
the weak..
Thanks.
Erms
Message 9 of 12
in reply to: ermin
Does anybody know how Solidworks handles
this? I know SW can mirror parts and assy's but what are the "problems"? (if
there are any)
Christian.
subassemblies.
wicket.
Sean Dotson, PE
...sleep is for
the weak..
Thanks.
Erms
Message 10 of 12
in reply to: ermin
I have only limited knowledge on this topic in SW,
but I believe basically it guids you through by means of an assistent that asks
you all those questions that were asked here under this topic (mirror/not
mirror, new filename, etc)
I believe, all the hassle is not realy worth
it.
Leo Laimer
Maschinen-
und Fertigungstechnik
A-4820 Bad Ischl - Austria
style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
handles this? I know SW can mirror parts and assy's but what are the
"problems"? (if there are any)
Christian.
would be next to impossible - especially if the assembly to be mirrored
EVERY part mirrored or just most?  It gets to be a sticky
wicket.
Sean Dotson, PE
...sleep is
for the weak..
Thanks.
simpler?
Erms
Message 11 of 12
in reply to: ermin
Leo
> I believe, all the hassle is not realy worth it.
The more I've thought about mirror, the more I can see the steps you go
through as not being worth it.
I can see that either you'll get asked too many questions, or if IV can
actually automate it there will be times when you wish it wouldn't.
Richard
Message 12 of 12
in reply to: ermin
Thats the common sense here after many discussions.
But What I really would like to see in IV, just in addition to the
derive/mirror:
make any part, make a idw off it.
mirror the part in a way, that all sketches/features stay intact, but
mirrored, and keep the idw associated to it (better yet, rename both in DA
before mirror)
So you end up with a mirrored part, fully parametric, with a finished idw
(may need some cleanup though), but with NO parametric relation to the first
part.
This feature would save me a lot of work on occassion.
I've done this in MDT many times with great success!
Leo Laimer
Maschinen- und Fertigungstechnik
"Richard Hinterhoeller" schrieb im
Newsbeitrag news:3DE3BDD9.9050808@hfx.eastlink.ca...
> Leo
> Richard
