No. The IDW will see the derrived part as a totally new set of sufraces and will therefore detatch all dimensions.
If you wanted to give it a try you could make a copy of the IDW, rename the original IPT to a different name, open the copied IDW and when it asks where the model is point it to the derrived component model. Then rename the original IPT part back to it's original name.
MechMan
