Inventor Forum
MIRROR TEXT
4 REPLIES 4
500 Views, 4 Replies
MIRROR TEXT
Good Morning,
I have created a structure with back to back angles for the x-bracing. I would like to label this with the reverse symbol of one L reversed and the other normal, is there anyway to acheive this?
Neil J
4 REPLIES 4
JDMather
Post screen shot.
Cadmanto
Once the text feature is created have you tried using the mirror command under the model tab?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
in reply to: Cadmanto
I am trying to do this in a drawing, so the model tab is not applicable.
Cadmanto
See if the method in this link works for you.
http://forums.autodesk.com/t5/Autodesk-Inventor/Mirror-text-in-idw-environment/td-p/2448418
Best Regards,
Scott McFadden
