Good Morning,
I have created a structure with back to back angles for the x-bracing. I would like to label this with the reverse symbol of one L reversed and the other normal, is there anyway to acheive this?
Neil J
Post screen shot.
Once the text feature is created have you tried using the mirror command under the model tab?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
See if the method in this link works for you.
http://forums.autodesk.com/t5/Autodesk-Inventor/Mirror-text-in-idw-environment/td-p/2448418
