Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Niels van der Veer
The Netherlands
This worked perfectly
@-niels-wrote:
If it's a user workplane (you made it) then you can RMB and select "flip normal" so the sketch faces the correct way.
If your sketch is on one of the origin planes you could make a new plane offset from that and use the same "flip normal" to ensure your text faces the right way.
