Hi! This behavior does not sound right. Could you send the file to me, so I
can take a look?
Thanks!
Johnson Shiue
Test Engineer
(email: johnsonDOTshiueATautodeskDOTcom)
wrote in message news:5220493@discussion.autodesk.com...
Inv 11 - SP 1
Pentium 4 - 3.8 GHz
2.00 GB of RAM
Windows XP Professional - SP2
I am working in a weldment in which I would like to mirror the machining to
the other side of the machine using the origin as the mirror plane.
I have been able to due this but I find my machine going extremely slow. In
once case it took 50 minutes to mirror 2 holes and a chamfer. If I need to
make a slight change then I'm stuck waiting for at least 20 minutes if not
more to do a simple command.
Is this due the fact that I mirrored machining? I didn't have this problem
until I started the machining phase of my project.
Please note that I have no welds in this model due to company standards.
Also in the attachment I have the machine suppressed so I can work in the
model. If I did not it would take me at least 30-45 to do a simple changes.
As it right now it will take me at least 50 minutes to turn the machining
back on
