hi
i mirrored a sheet metal the length in the folded model carried on to the mirrored part,
but i cant get the dimension of the flat part of the original part.
is there a way to do this.?
help
inventor 2011
vault pro 2012
No, as designed. If you did the Derive/Mirror, you would need to then convert this item to a Sheet-Metal with the correct thickness and then do the "Flat-Pattern" to get the flat lay-out. Most likely you have omitted this operation and your part is only a part and not a Sheet-Metal part.
Your best bet may be to mirror copy just the sketch, then create the mirrored part if you want a flat pattern for both original and mirrored part. Our shop just shows the original as "a L - AS SHOWN" then lists the mirrored part as "a R OPP HAND". This way the shop knows it must create a as shown and opp hand part. Some require showing both the as shown and opp hand parts, if such is the case you will have to create the opp hand part and vcreate a flat pattern for it, unless your flat pattern would be a mirror if shown from the back, then simply place another view of your flat pattern from the back and manually name the part, editing your bend notes to read the opposite direction of bend..
Hi! If you want to capture the parametric dimensions in the drawing view, you can simply place a back view (assuming front view is the mirror source) and retrieve the dimensions. But, you have to keep a note distiguishing the difference. Otherwise, it will be confusing to people looking at the drawing.
Thanks!
Just use the flat pattern then from the original part. Your break-up and break-down will be wrong. Instead of placing the view Top, use the view Bottom
Unforuntate, the answer to the question would be no. The flat pattern body is always in sync with the folded body.
Thanks!
Open your mirrored part, go to parameters. At the bottom hit the link button. Find your original part and select the parameters you want to link and select them. These will know show up in the mirrored part.
then go to the Parameters and add a custom parameter with your thickness name and add the value. it will then show in your BOM.
make sure you have the export checkbox checked in the part parameters for you thickness. In my example i have 3 set for export.
