Inventor General Discussion
wmd2
Message 1 of 12 (556 Views)
Mirror command?
556 Views, 11 Replies
10-24-2012 10:22 PM
In the attached file is an illustration of a vise base. What is an expedited technique to duplicate the padeyes seen in the isometric view to the other side? Thank you in advance
Will
Valued Contributor
machiel.veldkamp
Message 2 of 12 (544 Views)
Re: Mirror command?
10-25-2012 03:01 AM in reply to: wmd2
You need a work plane in the center of the model you're working on.
You can either do that by editing your first exstrusion and place that one in the center (then you're done (exept the model freaks out..)) or, you can make a new work plane by pressing ']' and selecting the two oposite sites of your model, then a work plane will be placed in the center of those to planes.
Then you have a usable workplane that you can use.
___________________________
Inventor 2012 lastest service pack
RAM: 24GB DDR3 / CPU: Intel Xeon W3690 @3.47Ghz
Video: NVidia GeForce 680/ HDD: 15.7K
Windows 7 Pro 64-bit
wmd2
Message 3 of 12 (493 Views)
Re: Mirror command?
10-26-2012 12:52 PM in reply to: machiel.veldkamp
In fact it did freak out. The attachment shows the following run time error; R6025 pure virtual function call
JDMather
Message 4 of 12 (469 Views)
Re: Mirror command?
10-26-2012 05:27 PM in reply to: wmd2
Attach ipt files, not pictures.  Can't edit pictures or see clearly what you did in pictures.
Doesn't look to me like you have created correct mirror plane as shown in previous response.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
JDMather
Message 5 of 12 (467 Views)
Re: Mirror command?
10-26-2012 05:28 PM in reply to: JDMather
Your Sketch1 is not constrained or placed with a logical orientation to the origin.
I recommend you start here http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
JDMather
Message 6 of 12 (466 Views)
Re: Mirror command?
10-26-2012 05:33 PM in reply to: wmd2
Line not vertical?
Line has unmanufacturable dimension
Extra horizontal line at bottom.
Horizontal line at top not dimensioned.
wmd2
Message 7 of 12 (448 Views)
Re: Mirror command?
10-27-2012 04:29 AM in reply to: wmd2
Attached please find the sketch in its current form. Thank you
JDMather
Message 8 of 12 (427 Views)
Re: Mirror command?
10-27-2012 10:11 AM in reply to: wmd2
Why?  Did you attach the correct file?  You didn't fix any of the issues in this file and there is no mirror plane?
wmd2
Message 9 of 12 (425 Views)
Re: Mirror command?
10-27-2012 10:20 AM in reply to: JDMather
You are very responsive. And your responses are very anticipatory. But that's good
JDMather
Message 10 of 12 (422 Views)
Re: Mirror command?
10-27-2012 10:56 AM in reply to: wmd2
Extrusion1 should be mid-plane (Symmetric).
Sketch2 is not constrained.
Sketch7 is not constrained.
Sketch9 is not constrained.
