I have mirror assembly. Created with mirror command.
Is it possible so this mirror assembly automatically follow changes in parent assembly? All changes I mean. So for example if I make pattern of parts this pattern was also added to mirror assembly. Also if I add some component, etc.... All changes.
Cris.
Solved by blair. Go to Solution.
No, there is no link to the parent IAM. It's a one off run not like "Derived" that will maintain a link to the parent unless explicitly broken
