Inventor Forum
minimal DXF
0 REPLIES 0
Message 1 of 1
783 Views, 0 Replies
minimal DXF
I have written a little program that exports some data in a DXF file R12.
Works fine, but I now need to export splines. R12 does not support splines.
Higher versions of DXF support splines, but I have been having trouble creating a simple R14 file that works.
It apparently isn't enough to create an entity in an entities section, some other mysterious data is needed.
for example, this is a valid R12 dxf file:
0
SECTION
2
ENTITIES
0
POINT
8
POINTS
10
1129.37750048186
20
1151.48159030391
30
105.53332335643
0
EndSec
0
EOF
but good luck trying to get something like this working as a R14 format (or higher).
To find out what I was missing, I created a simple spline (4 control points) in autocad and saved it as a DXF..
The result is a file packed with data that (although no doubt usefull to the autocad application) is in fact worse than useless to me as it seriously inhibits my attempts at deciphering the format. So, if anyone would be so kind as to explain to me:
What do I need to include besides an entities section in order to constuct a valid DXF R14 file?
Does anyone have a bare-bones no-nonsense DXF R14 file they could post for me as an example?
(p.s. in fact, it doesn't have to be R14, could be higher for all I care. I just want to be able to create a DXF file that contains splines).
Thanks.
Tags (2)
0 REPLIES 0
