Hi All
Does anyone know of this issue where the Mini Toolbar for Extruding/Sketching on the face of a part is larger than normal (almost as if it has been magnified)?
I have attached a screan capture to show this, you can see the size of the Mini Toolbar in relation to the standard sized View Cube.
Can anyone help with a fix/option to get the Mini Toolbar back to its origional (Mini) size?
Kind Regards
Carl van Rooyen
Solved by cbenner. Go to Solution.
Just to ad dto this post.
It is the Edit Extrude / Edit Sketch and Create Sketch GLYPHS that are enlarged and look as if they are magnified.
Check this setting:
Just a thought.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
