Inventor Forum
Migration help
20 REPLIES 20
Message 1 of 21
265 Views, 20 Replies
Migration help
What the is going on. I can't seem to migrate from 5.3 to 6.
i use the inv 6 migration program and on one computer it frezzes after doing 6 files and the other computer freezes after doing 8 files. i have tried everything but still no luck. this is keeping me from getting any work done at all.
i have over 3,000 files i need to migrate. does anyone know how to fix this? i have already reinstalled inv 6 and all that crap that you shouldn't have to do all the time.
ps i had not one problem going from 5.0 to 5.3.
1.9 p4
1.3 g ram
ati video
40 g hd
winn 2000 pro
20 REPLIES 20
Message 2 of 21
Have you applied service pack 1 yet?
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
What
the is going on. I can't seem to migrate from 5.3 to 6. use the inv 6
have
the time.
1.9 p4
1.3 g ram
ati video
40 g hd
winn 2000
pro
Message 3 of 21
yes
Message 4 of 21
accu-cad
I noticed some larger files seemed to hang. I crashed out and restarted and they seemed to hang again but it was late in the day so I let them run over night. In the morning I expected to reboot but the files were migrated. So what I found out is give it time. Especially on files that have large perf patterns or lots of punched holes. I migrated one this morning it took 3+ hours. 565 punched holes.7 flanges. good luck
accu-cad@velocity.net
Message 5 of 21
The files i started with were just steel shapes at different lengths. one comp freezes after doing 6 files
and the other after 8. i haven't even got to the large files
of unit assemblies or weldments yet. right now just trying to do steel shapes and fastners. you can have the same part
saved as 7 different names and it will freeze up after trying to migrate the 6th one every time. i let it set for over an hour and nothing.....
Message 6 of 21
can you open the assemblies and do the migration
during opening or does it hang there too? if so it might be a video
issue?
The
the large files
saved as 7
nothing.....
Message 7 of 21
I think someone from autodesk suggested changing
the hardware acceleration to Microsoft generic (lowest setting) then running the
utility.  Has to be worth a try.  It did work on one of my
assemblies.
Kathy Johnson
The
the large files
saved as 7
nothing.....
Message 8 of 21
If this is true then this may be his problem.
Notice the first post.  ATI video card..
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
FAQ for most common questions
href="http://www.sdotson.com/faq.html">http://www.sdotson.com/faq.html
the utility.  Has to be worth a try.  It did work on one of my
assemblies.
Kathy Johnson
The
the large files
saved
nothing.....
Message 9 of 21
Look back in some of the earlier posts. I thought there was an issue
with memory leakage due to the video setting and a recommended setting
that would overcome this.
Richard
Albert Allen wrote:
> can you open the assemblies and do the migration during opening or does
> it hang there too? if so it might be a video issue?
> "TC" <1john@liftaloft.com <1JOHN>> wrote in
> message news:f12bf9d.3@WebX.maYIadrTaRb...
> nothing.....
Message 10 of 21
Hey TC, another idea if you have the HD space.
Copy all your ipt,iam,idw's etc. over to another location
and play with migrating there and keep you original stuff and work on it
with 5.3. When you get time you can dink with 6 and migration and not affect
your current work. 5.3 and 6 seem to co-habitate fairly well on the same
machine.
What
have
the time.
1.9 p4
1.3 g ram
ati video
40 g hd
winn 2000
pro
Message 11 of 21
I will try the generic video driver and see if that helps. i will let you know. also i have copied the files from the server to my local drive to migrate.
thanks
tc
Message 12 of 21
I don't understand why the video setting is
important. When inventor migrate the files with the migrate tools, inventor
is not open on the screen...
I have migrate all of my files.
3000 ipt files in 8 hours .....P4, 1,7 Ghz, 512 MB
RAM
"Sean Dotson" <sean at sdotson dot com> a écrit dans le message de
news:
href="mailto:1C6D7282B0FBE9B6BE6374363F713CB5@in.WebX.maYIadrTaRb">1C6D7282B0FBE9B6BE6374363F713C...
problem.  Notice the first post.  ATI video card..
Sean Dotson, PE
Check the Inventor
changing the hardware acceleration to Microsoft generic (lowest setting)
then running the utility.  Has to be worth a try.  It did work on
one of my assemblies.
Kathy Johnson
The
to the large files
nothing.....
Message 13 of 21
As far as I can tell Inventor opens up for each
migration and if Inventor is on then video is important.
inventor is not open on the screen...
MB RAM
de news:
href="mailto:1C6D7282B0FBE9B6BE6374363F713CB5@in.WebX.maYIadrTaRb">1C6D7282B0FBE9B6BE6374363F71...
Sean Dotson, PE
Check the
Inventor FAQ for most common questions
on one of my assemblies.
Kathy Johnson
The
same part
and
nothing.....
Message 14 of 21
During the migration, to inventor is launched in
bottom of task but on no account it appears to the screen.
MB RAM
de news:
href="mailto:1C6D7282B0FBE9B6BE6374363F713CB5@in.WebX.maYIadrTaRb">1C6D7282B0FBE9B6BE6374363F...
Sean Dotson, PE
Check the
Kathy Johnson
The
the same part
an hour and
nothing.....
Message 15 of 21
If you look at any migrated files you will see that the preview bmp is
updated to reflect the new background that you have configured in R6,
therefore there is some background video interaction going on, whether you
the user actually sees it or not is a moot point.
IMHO, if the card is not certified, it shouldnt be on the machine. period.
- drew
Drew Fulford B.A.Sc. Systems Engineer
Solid Caddgroup Inc. Burlington, Ontario
Tel: (905)331-9670, Fax: (905)331-7280
Corporate: http://www.solidcadcam.com/
Member of the Autodesk Discussion Forum Moderator Program
Visit my MCAD website @ http://www.mymcad.com/
"Dominique >" < wrote in message
news:3E9A23312589AEA72E98A5EBFC49AD2A@in.WebX.maYIadrTaRb...
> I don't understand why the video setting is important. When inventor
migrate the files with the migrate tools, inventor is not open on the
screen...
> 3000 ipt files in 8 hours .....P4, 1,7 Ghz, 512 MB RAM
> "Sean Dotson" a écrit dans le message de news:
1C6D7282B0FBE9B6BE6374363F713CB5@in.WebX.maYIadrTaRb...
> If this is true then this may be his problem. Notice the first post.
ATI video card..
> Sean Dotson, PE
> Check the Inventor FAQ for most common questions
> "KJohnson" wrote in message
news:146F51829BBC3B107CEA4A7C9FA5A632@in.WebX.maYIadrTaRb...
> I think someone from autodesk suggested changing the hardware
acceleration to Microsoft generic (lowest setting) then running the utility.
Has to be worth a try. It did work on one of my assemblies.
> Kathy Johnson
> "TC" <1john@liftaloft.com> wrote in message
nothing.....
Message 16 of 21
"IMHO, if the card is not certified, it shouldnt be on the machine. period.
- drew"
My card is certifiable does that count?...no wait it's me that is
certifiable...ok forget it....
I do agree though 100% not that my opinion is worth anything.
"Drew Fulford" wrote in message
news:A43E0A6FEA288BE9CE4429A6A934075F@in.WebX.maYIadrTaRb...
> - drew
> screen...
news:
> ATI video card..
> > Sean Dotson, PE
utility.
> > Kathy Johnson
> nothing.....
Message 17 of 21
ok autant pour moi, je viens de faire le test et effectivement le fond
d'écran et mis à jour. donc il y a effectivement quelque chose à faire avec
la carte graphique. Ce qui est fort tout de même..
Donc on peut à ce moment régler les paramètres graphique au minimum pour
améliorer la rapidité de la migration.
OK as much for me, I have just made the test and effectively the bottom of
screen is updated. Thus there is effectively something to do with the
graphics board. What is strong all the same.. Thus one can at this moment
adjust the parameters graph at least to improve the speed of the migration.
Meilleures salutations
Dominique
"Drew Fulford" a écrit dans le message de news:
> - drew
> screen...
news:
> ATI video card..
> > Sean Dotson, PE
utility.
> > Kathy Johnson
> nothing.....
Message 18 of 21
AND THE PROBLEM WAS...........ATI VIDEO DRIVER
thanks for all your help guys and gals.
after changing from the ati driver which worked fine in 5.3
to the generic windows driver everything is migrating along just fine with no freeze.
(now if you people can help me to talk the big wigs into buying me new video cards i would be all set lmao)(have been trying since january)
Message 19 of 21
jmartzig
TC, just show them this post - it speaks for itself in getting you a new video card. -Joe
Message 20 of 21
Yeah, I'll bet you spent more of their money solving this problem than
the new video card would have cost.
> video card. -Joe
