Inventor Forum
Migrating from Inventor 2011 to Inventor 2010
4 REPLIES 4
JavZaMa
275 Views, 4 Replies
Hi, I have generated a mold assembly on Inventor 2011, but I have to migrate these files to Inventor 2010, because is the version I use in my job, IT manager uninstalled Inventor 2010 and installed 2011 version, I worked on it but then back to work on 2010 version. Is there a way to do it?
Tags (1)
4 REPLIES 4
jletcher
in reply to: JavZaMa
no..
Step file is the only way to go backwards..........
JavZaMa
in reply to: jletcher
ok 😞
Do I have to do it with the Content Center Files too???
jletcher
I do not know if they was made with 2011 and saved but I do know that CC parts are not migrated through autodesk. So some of the CC files are in 2008 format.. You may get lucky Smiley Happy
john.laidler
Content Center files are 'ipt' files, and also are not 'backward compatible'.
John Laidler
AutoCAD, Inventor and Vault
Please use "Accept as Solution" & give "Kudos" if this response helped you.
