Every time when I upgrate Inventor to new version, my old assembly drawing will loss the content center file. So I have to replace the old version's content center file from the new version's content center file. How to automatically migrate it?
Solved by alessandro.gasso. Go to Solution.
I hope you can find useful the blog post below.
http://beinginventive.typepad.com/being-inventive/2012/05/content-center-file-versions.html
Kind regards,
Alessandro
Sorry I thought I solve the problem, but I launch my "task scheduler". It is empty. Please see the print screen attached.
This was a known issue that has been fixed in the SP1, so, I suppose you have not installed it.
If this is the case, you can install directly the SP2 for Inventor 2012 that contains the SP1 fixes as well.
I hope it helps.
Kind regards,
Alessandro
Hi All,
I am not able to see any standard parts list in Contents Editor. It is shown blank. Is this procedure also required when the contents center is used from Vault Server?
