Made the move from 2013 to 2014 Inventor. Should I migrate files that I'm going to work on or open the assembly and then do a 'save all' in master representation level? I have been doing the save-all routine until now because it's just faster and can be done on a as-needed basis. Which is best or are the methods equivalent?
Thanks.
Pete
Solved by mcgyvr. Go to Solution.
IMO its best to (first backup all files of course) and then migrate all files via task scheduler when you update to a new release.. (I do parts first.. then assemblies.. then idw files)
If you only migrate when you open files to work on them you have a good chance of possibly going years between migrating some files you don't use that often.. And thats not recommended at all.. Something about don't let them get more than 4 versions behind or you could have problems/corrupt files,etc...
Before we Migrate, all Inventor files are backed up (in this case to DVD for archive purposes) even though the network does a full backup each evening. We then run the the Task Scheduler and migrate all IPT files first, then run it a second time for all the IAM files, thirdly for the IPN files and the last time we run it is for the IDW's.
I'm sure others have different methods, we've been doing it this way since IV5 (started on IV4).
