I am following the help to try to migrate materials, but I always get an error:
Thought maybe was a permissions issue, but I get the same error if I try to save to local hard drive.
Anyone having this problem?
John
Solved by NicolasXu. Go to Solution.
is this what your trying to do: http://beinginventive.typepad.com/being-inventive/2012/05/migrating-content-center-libraries-with-cu...
DarrenP
Did you copy/move the Design Data folder?
What's the Design Data folder location & the InventorMaterialLibrary.adsklib location in the Project file? You may use the default location and give a try.
Nicolas
