how can i keep the x-axis symmetric about y-axis.
sometimes the two lines doesn't seem to intersect at origin.
please guide me with a appropriate solution
thanks,
pavan
@Anonymous wrote:how can i keep the x-axis symmetric about y-axis.
thanks,
pavan
Welcome!
Are you saying that the origin axes do not intersect? I would have to see that. If that is actually the case you have something seriously wrong. What version of Inventor are you using? Please attach a file that shows this behavior here.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Paven,
Welcome to the forum.
I know the axis and planes adjust as geometry is created, but it they started out intersecting they will always intersect.
Now, if you created a template that didn't have them intersecting to start with then they never will. We created our template from the out of the box part template which do intersect.
If you could provide an image that would help greatly.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
