Inventor Forum
Mid point valid for dimensioning
6 REPLIES 6
221 Views, 6 Replies
I have been told and shown on an different PC that a mid point of a line is a valid point to dimension something from. however on my PC i cant get it to work. Is this part of an add on program that make midpoint valid for dimensioning, or do i just need to change a setting in my inventor?
6 REPLIES 6
I think you've been misled. You cannot DIRECTLY dimension to the midpoint of a line. You CAN directly use a line midpoint as a constraint selection, or you can drop a sketch point or hole center on a line midpoint and dimension to that.
in the IDW place a sketch on the line you want to dim to the center
then dimension to that.
I have done this a ouple of times.
Lloyd
Sorry i mean in a sketch, when dimensioning up i was show dimensioning from a mid point of a line. I have always done it before by drawing a little line in from the mid point perpendicular to the line u are wanting to dimension from, but this was definately from the green midpoint.
I think maybe he was showing us with Inventor 8. there are loads of little things he showed us that i just cant find.
I can get ordinate dims to dim to midpoints, but
that's it. Other wise I have to use the sketch technique if I want to use
anything else besides ordinate dimensions.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">I
inventor?
The best way to accomplish this is to place a sketch point at the
midpoint, The sketch point is constrained to the midpointm allowing the
dimension to be placed. There is no possibility of selecting the
midpoint of a sketch line for dimensioning without the point. It works
the same way in an IDW.
Dennis
> midpoint.
Dennis Jeffrey
Autodesk Product Consulting and Training
Center for Design Excellence
http://www.engineering-helpdesk.com
http://www.design-excellence.com
260-459-1311 ext 221 or 800-550-6070 ext 221
