Inventor Forum
Metric to Imperial conversion
8 REPLIES 8
Message 1 of 9
rgarthe
2774 Views, 8 Replies
I have some math models and drawings in metric units that were created in Inventor 2009. How can these files be converted to imperial units (inches). I to use Inventor 2009.
8 REPLIES 8
Message 2 of 9
in reply to: rgarthe
you do not need to 'convert' - Inventor does it. change your set up from imperial to metric. in any set up yo can enter any dimensions you like just type correct value egz: "1 in" or "5 m". in drawing use metric expresion dimension style instead imperial.
Cheers
Message 3 of 9
JDMather
Perhaps Tools>Document Settings>Units tab is what you are after.
Message 4 of 9
http://www.cbliss.com/inventor/iCode/index.htm
Scroll down to Change Units of Measurement
Duncan
"Humour ... is one man shouting gibberish in the face of authority, and
proving by fabricated insanity that nothing could be as mad as what passes
for ordinary living."
(Terence 'Spike' Milligan K.B.E., 1918-2002)
www.autodesk.co.uk/inventorjobs
http://support.microsoft.com/default.aspx/kb/555375
wrote in message news:6086930@discussion.autodesk.com...
I to use Inventor 2009. Thanks
Message 5 of 9
rgarthe
I've followed your recommondations, which work, to a point. The converted file needs to translate into MasterCam as the converted part units. In other words if I change from metric to inch in Inventor 2009, the model needs to translate into MasterCam as an inch model. The methods I've been using the model translates to MasterCam in the orginal units, in this example metric.
Hopefully, I've missed your point, or did not follow directions correctly.
Any hints?
Thanks!
Message 6 of 9
rgarthe
Any hints?
Message 7 of 9
rgarthe
Any hints?
Message 8 of 9
msklein
GO TO tools then document settings, units tab and change units. Master cam should see created units as inches, if not you probably have some other problem. just to clarifiy.
Message 9 of 9
JDMather
Zip and attach the file here.
