Inventor Forum
Messurment problem while converting to STP file
3 REPLIES 3
345 Views, 3 Replies
Hi all,
what am i doing wrong. Afther finishing a part in Inventor 2014 a want to store it as a STL file. Thats no problem but  when the part is saved as STL it messurments don't add up any more. The STL file becomes a factor 10 smaller. So 50mm ends up as 5mm. So thats a problem. Does anyone know what is going wrong.
Thanks, Rene The Ntherlands.
3 REPLIES 3
JDMather
You title says STEP, not stl.
When Save Copy as type *.stl be sure to set Options the correct Units (same as model).
How are you checking the resulting size?
in reply to: JDMather
Hi thanks. This is not the solution sorry
Units are in mm also in options. And i check with metfab 3d software.
Rene
Verstuurd vanaf mijn iPhone
JDMather
Attach the ipt file here.
Zip and Attach the stl file here.
