Hi Becky,
Would you be able to give us some more information about the models and workflow; Have you tried using Meshmixer to close the volumes? Can you attach the models so that we can see what they look like? What 3D printer are you using?
Indy
p.s. How's your tyre model going?
here is one of the files.
I am hoping to diss assemple and make them solid. scale to 1:14 and print
Hi Becky,
Sorry for the late reply - it looks like the model has zero thickness (although it's difficult to tell since you attached the .ipt import instead of the original file), so even if you patched up the holes you'd still need to enclose some kind of volume before you try to 3D print it. This is best done in Meshmixer, did you try to load the .stl there?
Hope this helps,
Indy
