Inventor Forum
Merge I beam by Frame Generator
2 REPLIES 2
jyothissurendran
1203 Views, 2 Replies
I have three i beams, two of them are perpendicilar and one is diagonal to others. I am trying to merge the end of diagonal beam with the other two beams. I tried the options "Trim Extend & Notch" for merging this, but it does'nt work properly. i am not getting a perfet result. My intension is to merge the web to web and flanfe to flange.
Kindly advise if somebody knows any option. Please find the attached image more clear explanation.
Jyothis Surendran
Autodesk Autocad 2014 & Inventor Professional Suite 2010
Windows 10
2 REPLIES 2
JDMather
in reply to: jyothissurendran
Edit the beam to be cut in the context of the assembly.
Copy Object the cutting surfaces from surrounding parts as needed.
Sculpt or Split away the excess material.
jyothissurendran
in reply to: JDMather
Dear JD,
I got it merged by "notch and Trim/Extend".  Thanks for  your reply and time .
Jyothis Surendran
Windows 10
