IV6, sp2, on a Dell Precision 450, dual 2.4GHz, with 2.0 gb of ram and Paging file set to 4092 mb.
Problem happens while trying to update some assembly drawing views to a particular design view. Watching task manager, the "PF usage" goes up to 1.13 gb or so and then I get an error message in IV saying "Your Inventor session has used up more than 80% of the available process adress space. It is highly recommended that you close down some documents before proceeding further." Well try as I may, I can't seem to close enough things down to get this message to go away, and the only way to get out of it is to crash out of IV. Should this really be a problem with the computer setup I have? Are there any settings that I should check to avoid this problem in the future???
Phil Eichbauer
RWC Inc.
