Inventor General Discussion
Distinguished Contributor
0 Kudos
Post 1 of 6
measuring hole cntr to cntr
51 Views, 5 Replies
11-14-2002 12:49 AM
I am having trouble measuring hole center to hole center.
When I use the measuring tool and click hole it measures the hole. The measuring tools are lousy. I am using Inventor 5 and probably will be for a long while. Does anyone know how to measure center to center?
Thanks -Bill
*KJohnson
Post 2 of 6
Re: measuring hole cntr to cntr
11-14-2002 12:50 AM in reply to: koehler
You need to RMB and select other to get the point
or axis.  But the first is the diameter of the hole.
Kathy Johnson
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
When I use the
-Bill
0 Kudos
Post 3 of 6
Re:
11-14-2002 12:54 AM in reply to: koehler
Thanks, I feel I should have known that by now.
0 Kudos
Post 4 of 6
Re:
11-14-2002 10:02 AM in reply to: koehler
Same here. Took me a while to get the hang of it. Confounded thing has smarts built into it and adjusts the readout to what it is your measuring. Knowing how to use it now, I find it quite good.
JP
*Maenpaa, Mike
Post 5 of 6
Re:
11-14-2002 10:22 PM in reply to: koehler
What I usually do, when I don't feel like scrolling thought
the Select Other thing, is to pick corner of the part to get a point reference,
then when I select a circular edge it automatically uses the center point of the
arc.
Mike
Same
JP
0 Kudos
Post 6 of 6
Re:
11-15-2002 05:36 AM in reply to: koehler
Yup,
That's just what I mean (priming the measure tool by preselecting an edge or point).
It's not what you got, but how you use it.
jp
