Is there a way to get the dual unit option to read in both feet and inches....for instance 32.75 to read 2'-8 3/4" instead of 2.729 ft?
Anderson
Are you talking about dimensions in a drawing? Because "measure distance" makes me think of meaurements in a part or assembly. If you're referring to that drawing... I just tried this with setting the Alternate Units to "ft", Linear format to Fraction Not Stacked.
This is what I got....
Is that what you were looking for?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Pretty sure he actually does mean the measure distance command (for parts and assemblies). You can set a dual unit there too, so it reports measurements in inches and millimeters, etc.
Unfortunately, no, there's no way to even set the primary unit to fractional, much less the secondary. Ft-in measurements don't seem to be supported by the measure tool at all.
