I am trying to make an Meandro pipe with few strings together.
Adjusting the length and size between succeed me.
But now I want multiple strings, up to max12 parallel lines and a minimum of four lines side by side.
But I want the numbers turn on and off so I can put, say, 6 or 8 lines turn on and then stay together so the sweep will stil work.
The curl at the end should also continue to participate in the final line, that fails me now.
Can anyone help me on the way?
Mvg Jos
Your drawings are only as good as the symbols that complete them...
