style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"Mike Maenpaa" <
href="mailto:ReMOVE__ThiS_Mike.Maenpaa@eltekenergydottcom">ReMOVE__ThiS_Mike.Maenpaa@eltekenergyd...>
wrote in message
href="news:E47631C5701BE7C2C5E01BC8152DC7A7@in.WebX.maYIadrTaRb">news:E47631C5701BE7C2C5E01BC8152......
What does the Add-In Manager show. Is the DWG translator
loaded?
Mike
"rllthomas" <I
href="mailto:rllthomas@attbi.com">rllthomas@attbi.com> wrote in message
href="news:f192006.20@WebX.maYIadrTaRb">news:f192006.20@WebX.maYIadrTaRb...
suspect some dll needs registered but I have no idea what it is. I would
reinstally IV7. You might look at this though:
href="http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2878118&linkID=3016303">http:...
"rllthomas" <I'd
href="news:f192006.23@WebX.maYIadrTaRb">news:f192006.23@WebX.maYIadrTaRb...
look at what mechman wrote. If that doesn't help I would uninstall IV and
delete the install directory. If you made custom threads, stored your icode in
the install directory, kept your templates there or anything of that nature
you will lose it so you might want to backup your install directory.
Next I would delete the regkey
HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion7.0 (after backing
it up of course). You will lose your custom settings like where project
shortcuts are stored, ifeatures, username if you changed that etc. This step
is probably not necessary but increases your chance of sucess.
Now reinstall IV7 and SP1 and I would expect everthing to be
rosey.
"Andy Wilkinson" <
href="mailto:awilkinson@zonnet.nl">awilkinson@zonnet.nl> wrote in
message
href="news:66FCF6124AEFE827D8FB8202C005AF37@in.WebX.maYIadrTaRb">news:66FCF6124AEFE827D8FB8202C00......
I had a similar problem Cindy.
I had to do this to resolve it.....
Remove ALL AutoDesk
products,.even viewers etc
Edit registry to remove all AutoDesk strings with
reg cleaner
Re install
It didn't fix my problem the first time I
uninstalled until I uninstalled all AutoDesk products and edited the
registry.
Hope you solve it
Andy
"Mike Maenpaa" <
wrote in message
href="news:2434EDD2A8310E578D9B3DB77A9BFBFB@in.WebX.maYIadrTaRb">news:2434EDD2A8310E578D9B3DB77A9......
Installation order doesn't seem to have any influence on
translating MDT2004 to Inv. 7 on my machine.
Do you have the latest Service Packs for both MDT and Inv.
7?
I just translated a MDT2004 assy into Inv. 7 with no problem
at all. I basically accepted all of the defaults in all dialog boxes.
See the .ZIP file I have placed in Inv. Cust. Files of screenshots of all the
dialogs and my choices. If possible, can you post your MDT file ZIPped, in
Inv. Cust. Files. Maybe we can see if we are able to translate it or
not.
Mike
"Cindy Berend" <
href="mailto:crbdesign@charter.net">crbdesign@charter.net> wrote in
message
href="news:208C3EF254040E370B0AAF0D4C4CAA35@in.WebX.maYIadrTaRb">news:208C3EF254040E370B0AAF0D4......
Are you talking about actually installing the program
or just opening the MDT program before you open IV?
Cindy
